A/F ratio
Old Yesterday | 01:02 PM
Gary Ed's Avatar
Default A/F ratio
who can ajust air fuel ratio on XKR 2001 I have installed smaller top supercharger pullet new fresh air intake-improved exhaust ?
Old Yesterday | 05:38 PM
zray's Avatar
I wouldn’t be too sure you need to do anything . Have you driven the car since the modifications ?
Z
Old Yesterday | 08:01 PM
Y2KJag's Avatar
Unless you've done something seriously radical, the ECU will compensate. If you've done something so radical that the airflow is outside the ECU's parameters, you're likely looking at upgraded injectors and a remap of the ECU and a few cubic dollars. Maybe someone here knows a tuner. I'm under the impression that the X100's ECU code is proprietary and not many tuners will futz with it.
Old Today | 06:17 AM
daveb97's Avatar
Do a hard reset of the ecu disconnect the battery touch the positive negative leads together. That will clear the ecu then it will start relearning itself take it on a run or search this forum for relearning procedure and the ecu will learn itself again
jordanmc
Sep 13, 2024 01:41 PM
ben mensforth
Jul 3, 2024 07:24 AM
GWS
Sep 26, 2020 05:43 PM
CoxynotKirsty
Jan 10, 2015 05:38 PM
lcyoung
Sep 10, 2012 08:57 PM
Currently Active Users Viewing This Thread: 7 (1 members and 6 guests)
