Optional tire sizes in 18”
Old Yesterday | 06:58 AM
zray's Avatar
Default Optional tire sizes in 18”
Who had tried using the same size front and rear to be able to rotate tires (a little). I’d like to keep the stock 18” wheels but use the same size tires all the way around.
possible ? What size works ?
pipe dream ?
stock tire size is 245/45-18 front and 255/45-18 rear.
Z
Old Yesterday | 08:23 AM
Jon89's Avatar
I rotate side to side keeping the wheels on the same axle. That is about all you can do with staggered wheels....
Old Yesterday | 09:45 AM
zray's Avatar
Ive been unable to do that since most performance tires are directional. If I swapped the rear driver side to the rear passenger side then the tire would be rolling backwards.
I’m just wanting to be able to swap the rear tires to the front and have it be OK despite the front wheels are not the same width as the rears………
and since I’m wishing, I want a tire with a little more sidewall so the wheel well is filled up better.
Z
Old Today | 07:50 AM
wymjym's Avatar
So your wheels are the same width?
My xk8 has staggered wheel sizes.
I generally replace the fronts once for every two rear replacements.
WJ
Old Today | 08:47 AM
zray's Avatar
WJ
no, I have the stock 18” wheels (double nickel) that are 8” width on the front and 9” width on the rear. That’s why I’m more concerned about putting the same size tire on all 4 wheels.
the size I’m thinking about putting on all 4 wheels is :
245/50-18
Comments ? Anyone used this size on their staggered wheels ? Or any size that isn’t the stock 245/45-18 front and the 255/45-18 rear ???
Z
Old Today | 11:23 AM
jhuertas's Avatar
In theory, it's possible. If a +/-3% error in the diameter is acceptable, you need to know the maximum and minimum widths each rim can accommodate. Since both are 18", the front would be fitted with a tire at its maximum width, and the rear with one at its minimum. But I suspect there might be another problem: the synchronization of the rotation sensors. I suppose they're programmed to distinguish between the tire sizes permitted in the vehicle registration document and could give an error in other cases (can anyone confirm or deny this suspicion?). I have these rims and haven't considered this issue, as I specifically like the front tires to be narrower than the rear ones. I also have a set of 17" rims, but since I couldn't find a 245 width, I fitted 235s. I suspect the sensors gave me an error that I attributed to the change in tire size. But it's just a suspicion; I have no confirmation. I hope someone can confirm or deny this.
Per
May 31, 2020 07:21 PM
doctordeuce
Feb 11, 2015 03:32 PM
prodigy215
Feb 17, 2012 02:49 AM
Tiago
Nov 10, 2010 11:01 PM
v8stype
Aug 17, 2008 09:07 AM
Currently Active Users Viewing This Thread: 7 (2 members and 5 guests)
