Please help I’m lost 2003 x-type security failure
if you know of someone who can fix this in my area please let me know !! Rockland county New York
2003 Jaguar X-Type 2.5 V6 - PATS/Immobilizer Programming Fails After Security Access
I’m looking for help diagnosing a PATS/immobilizer issue on a 2003 Jaguar X-Type (X400).
Symptoms:
What happens:
Has anyone seen SDD gain security access, erase keys successfully, then lose communication exactly when the key data is written? Would you suspect corrupted PATS/EEPROM data, cluster/IP failure, network/GEM issue, or SDD/J2534 communication failure?
Any known fixes or common causes on the X400 platform would be appreciated.
Symptoms:
- Car will not start due to immobilizer/PATS issue.
- Original cluster had the problem.
- Installed a replacement cluster that was fully cloned (EEPROM/PATS/VIN/mileage transferred from original cluster).
- Tried 3 different transponder rings.
- Tried original key plus newly programmed transponder keys.
- Battery voltage is 12.9V.
- Wipers, lights, interior functions, etc. all work normally.
What happens:
- SDD identifies vehicle correctly.
- SDD communicates with Instrument Pack (IP).
- Immobilization Setup starts normally.
- Security access countdown completes successfully.
- Existing keys are erased successfully.
- During key programming, immediately after the countdown and write attempt, SDD loses communication.
- Error displayed:
“Failed to re-establish communications - returning to main menu”
Testman error: 12 57 20465
- B1213 - Anti-theft number of programmed keys below minimum
- B1601 - Passive anti-theft system received incorrect key code from ignition key transponder
- The instrument cluster appears to click/reset at the exact moment the programming write occurs.
- SDD occasionally shows GEM/FETM/PAM not responding.
- Sometimes SDD asks for vehicle specification/configuration information.
- Immobilizer setup never completes and never reaches successful enrollment of the keys.
Your problem may originate in your version of SDD. There have been online reports that the newer versions can have problems with older cars. I know Google AI is not the most dependable source, but try Googleing :
Will SDD v167 suit my MY 2003 X type Jaguar
and it may introduce you to some new ideas to pursue.
When you are trying to reprogram, how many keys are you trying to program. Do you have any linked already when you try to add more keys?
I have two new keys and one original the orginal one worked for at least 10 years and it seemed to be fine. I had let the car sit for a bit and I guess the battery died cause after I charged the battery this whole mess started
It seems y’all are correct the software I had didn’t seem to wanna work locksmith came had a different software. I don’t know what brand or whatever it was but took about 20 minutes and he fixed it so after $400 worth of tinkering around buying product it’s finally fixed now. I have to admit this guy charged me a ridiculous amount of money to fix it. $130 to cut two blanks that I provided to him and then he wanted another 300 after he did the reprogramming he knew I was desperate in a particularly stings because before I paid all that money he was out and said the ring was bad so I bought another ring ended up buying another cluster, but another battery turns out most likely when he came back. He brought a different tool, and that fixed it when he could’ve just used that tool in the first place where to save me all the money.
but in the end, it was all of your advice and observations that helped finally narrow it down so thank you. I’ll appreciate it.
Arsenal01
General Tech Help
28
Mar 1, 2025 09:22 AM
TheBdog
Jul 5, 2023 09:49 PM
