Broken door tweeter housing - potential solution
Old Jun 10, 2026 | 02:23 PM
Juss's Avatar
Default Broken door tweeter housing - potential solution
Just wanted to post this as a potential tip. I’m sure everyone knows how fragile those tweeter housings are on the car door. And I’m sure you also know how ridiculously expensive they are to replace second hand!
I broke the ring surround on my housing when removing it for work on the door. It’s been bugging me for a long time. So I took a punt on buying some cheapy stick on Grand Jeep Cherokee tweeter trims on Ebay. See attached.
While they’re not a perfect solution, they’re virtually the correct size and they cover the broken ring just fine for me. I was lazy and just stuck them on, but I would imagine if you spent some time working out a simple fix for keep the speaker mounted from the rear of the housing, you could also remove the broken part and replace with these for a snugger fit.
Unless you knew that this was a cheap cove mounted with 3M, you’d never spot it was a cheap add on. The attached flash photos are not the most flattering though and they look better in person.
I’m just glad I don’t have stare at the unsightly break every time I’m driving and thought it might be useful for others with a similar problem…..
Old Jun 10, 2026 | 03:59 PM
HealeyJag's Avatar
Nice work.......
Interesting solution!
Old Jun 11, 2026 | 04:37 AM
saajaguarx's Avatar
Thank-you for the idea. Ordering some Jeep rings now!
Old Jun 11, 2026 | 05:15 AM
Juss's Avatar
My pleasure. As I said, it’s not absolutely perfect, but it looks miles better than before.
Old Jun 13, 2026 | 08:37 AM
Sean W's Avatar
Nicely done
Old Yesterday | 06:28 PM
Tiepolo's Avatar
Hi Juss,
The simplest way is to take it or the other one and bring it to any 3D print service.
That should cost around 30$ or so and after some sanding you'll get exactly the right piece.
Old Today | 12:27 AM
Juss's Avatar
Originally Posted by Tiepolo
Hi Juss,
too much hassle for me.
Old Today | 03:18 AM
steve_k_xk's Avatar
I think that is a brilliant solution great job
Jeff Wallman
Mar 17, 2021 08:59 AM
retroren
XJ40 ( XJ81 )
May 31, 2019 10:19 PM
Tbilisi79
Feb 6, 2019 05:31 PM
iRuslan
Jul 2, 2018 12:57 PM
hawkmaster1
Apr 16, 2018 03:36 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
