Sights N Sounds Post all of your video and sounds clips here.
A few Jags from the Mad Dogs and Englishmen Show
Old Jul 13, 2015 | 08:03 AM
Scottsgreenjag's Avatar
From: Somewhere south of Grand Rapids, Michigan, USA
Default A few more Jags from the Mad Dogs and Englishmen Show
Old Apr 20, 2023 | 01:21 AM
david f100's Avatar
Fender repairs….
Old Apr 20, 2023 | 01:25 AM
david f100's Avatar
Floor pans …..
Old Apr 20, 2023 | 06:07 AM
Default Hmmm
Must be fun finding F100 parts in your corner of the world. Are you returning it to stock or are you going to "modify" it a tad bit. V8 or straight 6?
Old Apr 20, 2023 | 06:53 AM
david f100's Avatar
Have to import most bits from the US via Sea freight, so takes a while but Air freight on the big bits is pretty expensive
I’ve already had the new engine installed
Jaguar XJR supercharged V8 !
apologies, I meant to post the above Pics on a thread I had previously started on my XJRF100!
maybe admin can move them to the correct thread ? ….sorry !
Old Apr 21, 2023 | 05:07 AM
I'll have to look for the other thread, I'd love to see the motor install. What are you going to use for a transmission and rear end ratio?
And, you probably have all your suppliers lined up but after owning a few Ford pickups over the years, I've had pretty good luck with these people.
https://www.lmctruck.com/
International shipping must be a fun process!
Old Apr 21, 2023 | 06:14 AM
david f100's Avatar
I’m using the entire XJR Engine , gearbox, ECU and loom
Its all been in and had it running, back out for body repairs
I have a 3.25:1 ratio with LSD and that ratio with the truck tyre size equates to the same as the XJR
Using LMC for most things , but I have to send parts to a shipping company and sea freight them else it’s mega bucks !
Apologies again for hijacking’s your Thread by accident !
Old Jul 18, 2023 | 09:12 PM
David Lagonda's Avatar
Now that's how you do rust repair! A+++ Just curious - why was the interior painted prior to rust work?
Old Jul 19, 2023 | 02:44 AM
david f100's Avatar
I had the whole cab media blasted , and then primed just to protect it from corrosion whilst I did the repairs
theres more on this build here ….
https://www.ford-trucks.com/forums/1...onversion.html
Bruce and Sandra
Mar 1, 2023 12:47 AM
Bruce and Sandra
Mar 1, 2023 12:46 AM
JeffR1
Photography
Feb 17, 2022 06:53 PM
Moo
Photography
Jan 25, 2012 04:42 PM
