Sights N Sounds Post all of your video and sounds clips here.
STR vs. Camaro SS
Old May 4, 2013 | 09:57 PM
QuartzSTypeR's Avatar
Default STR vs. Camaro SS
Back at the track! A couple of vids for you all, my STR vs. a new Camaro SS and a Pontiac Grand Prix GTP Supercharged.
Sorry, I didn't think I would have to point the GoPro further back to see that Camaro .
Best run of the night was a 13.7 @101.4 with a 2.0 60' with a DA just shy of 7000 ft (this would convert to a mid-upper 12 second pass @~107-108 mph at sea level).
Old May 5, 2013 | 11:48 AM
petthesweaty's Avatar
very cool. did the camaro miss the green light or miss a shift? that was wmbarrassing.
Old May 5, 2013 | 06:44 PM
They definitely did not launch well. Maybe it was their first time at the track?
Old May 7, 2013 | 07:24 PM
RDMinor's Avatar
I would think that supercharging, which pressurizes to absolute pressure, would not be effected very much by altitude. Yes the air is certainly denser at the lower altitudes but the supercharger pressurizes to the same manifold pressure regardless of altitude. I know that when they first equipped fighters and high altitude bombers with superchargers it was to regain the performance they lost when going to the higher altitudes that the planes were now capable of and not to increase their low level performance.
What am I missing. By the way, the GTP dust-off was pretty impressive as I think he just flat got beat while the Camaro jockey was asleep at the wheel from the get go.
Old May 8, 2013 | 11:01 AM
At this altitude, the engine compression is still going to be quite a bit lower. I may be getting the same boost levels, but I am definitely not making the same power at 6000 ft. that I would be a 0 ft.
Old May 9, 2013 | 10:20 PM
Anders Hansen's Avatar
The boost might be the same, BUT what you are compressing contains less oxygen = less power, you would be well faster at sea level.
Manjag
Oct 1, 2015 05:34 PM
JaguarSV8
Oct 1, 2015 01:58 AM
SoCalJagS
Sep 27, 2015 09:20 AM
