2.5 V6 belt tensioner
Old Dec 7, 2025 | 12:24 PM
Norcat's Avatar
Default 2.5 V6 belt tensioner
Does anyone know if you can replace just the pulley on the tensioner for the main belt or do you have to buy a complete tensioner? I have a whirring noise when cold which I suspect is one of the idler pulleys, I have to investigate when the rain stops!
Old Dec 10, 2025 | 08:21 PM
iownme's Avatar
i also answered this in the other post you made
the entire tensioner is quite cheap from what i remember and replacing the unit will be a whole lot easier and better for the car.
both the tensioner or the pulley can go bad.
i found that a 3/8" ratchet was too "tall" to fit between the tensioner and whats in front of it.
what i did was take an old ratchet and using an angle grinder i ground off approx half of the "square"
it was then able to slide into the tensioners square hole.
here is a link to my post back in 2012
MY POST HERE
http://www.jaguarforums.com/forum/x-...esolved-69195/
Old Dec 11, 2025 | 10:50 AM
Norcat's Avatar
Thanks for your informative reply, I replaced the whole tensioner about 8 yrs ago and the car hasn’t done a lot of mileage as its my weekend car. I started it yesterday and typically none of the 3 pulleys made a noise so I still don’t know which one was whining the other day. I may just replace all 3.
Jlohojo7
Oct 9, 2024 11:06 AM
itswemy
Mar 20, 2018 07:18 AM
dsetter
May 20, 2016 09:55 AM
YYC guy
Mar 2, 2012 07:18 PM
brgjag
Dec 18, 2010 10:07 AM
