Newbie in Luton Beds
Old Jun 22, 2014 | 08:19 AM
kgpumps's Avatar
Default Newbie in Luton Beds
Hi all, I am a new Jag owner , wanted one for ages. Picked up a metalic blue xk8 1997 last month, and got to work fixing the known issues, thermostat tower to ali, heater feed and return pipes, power steering cooler leak, headlining and cupholder repair. enjoyed every minute of the tinkering around especially the power steering fix where I brought some joiners and a small length of power steering grade pipe for £5 (around $8) at my local hydraulic tubing specialist (Hose and tube Supplies) and spliced them in. Total time including a total cleanup & pressure test and fill was 3 hours.
Got one more fix to do but unsure how to proceed. Get engine fault and Poor performance when i back off the throttle when driving (coasting) and pulled codes P1226 and P1227. It appears intermittent and usually after some miles so i guess when at operating temp. I think throttle body mech guard and due for a change of throttle body, but today at standstill I also got Stability Control fail.
Any thoughts, throttle body or ECM? Ta kev
Old Aug 31, 2014 | 09:15 AM
Heggz's Avatar
Hello mate just spotted your post, sorry cant help you with your problem, i am in luton just off of poynters rd small world hey
Old Sep 1, 2014 | 05:12 AM
kgpumps's Avatar
Update. I found the compartment on the drivers side engine bay that holds the brake servo completely filled with water. I have onblocked the drain hole and allowed it yo dry out. There is a part of the loom for the front brake sensor I'm there with a joint that was submerged ad well. Since dried put haven't had the fault
Kev
trickeyM
Feb 29, 2020 07:00 PM
08292
Nov 24, 2017 11:22 AM
Marka
22
Sep 11, 2016 12:09 AM
Msteiner
May 16, 2016 12:19 AM
Clare Jennings
Oct 4, 2015 05:43 PM
