US Lower Atlantic NC SC FL GA
Need good Jag mechanic in Raleigh
Old Oct 8, 2014 | 12:32 PM
stephenroadster2003's Avatar
Default Need good Jag mechanic in Raleigh
I have a 2003 XKR with a convertible top pump and hydraulic line issue that I need help fixing. Can someone refer me to a solid mechanic in Raleigh, NC who can help me?
Old Oct 8, 2014 | 12:35 PM
I just bought this car and was told the pump and lines where just fixed a couple of months ago. The garage I brougth the convertible top problem to said pump and hoses are bad. Need reliable mechanic help to check and fix reasonable. Thanks
Old Oct 8, 2014 | 01:39 PM
what are your symptoms???
Have you verified that the valve on the side of the pump is shut (clockwise) - if open, then no pressure through pump.
Are you getting any other spurious indications - which could be indicative of a weak battery?
Let's try and rule out the simple stuff first
Old Oct 8, 2014 | 04:28 PM
The shop say's there is a leak and the pump and hose needs replacement. They just replaced the motor and security module. Now top works but they say it is leaking. The guy I bought it from says the pump, hose and hydraulic fluid were just fixed 3 months ago.
Need to find a reputable cost effective mechanic to bring this to so it can be fixed. The price I got from the current shop is $2,100.00 for repair. Should be half of that, I think, based on previous repair. I've already spent $2,500 on other top repairs.
Hope you can help. Thanks, Steve
Isoruku
Jun 19, 2020 12:54 PM
tonimccloud
19
Jan 18, 2020 01:56 PM
tonimccloud
Sep 3, 2015 07:58 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
Terrance Williams
Aug 26, 2015 11:50 AM
