US Southwest AZ, TX, NM, OK
jr member needs help with motor mount xj(x300)
Old Dec 31, 2014 | 08:59 PM
blue's Avatar
Default jr member needs help with motor mount xj(x300)
I was able to remove the motor mount bracket on passenger(rhs) side by removing 3 bolts and lifting the transmission with jack...was thinking smooth sailing until I tried to remove the mount it is threaded on both sides and seems to tighten down into the frame...i;ve been trying to loosen it from the frame with vise grips with no success
Old Jan 7, 2015 | 01:08 PM
blue's Avatar
Default motor mount removal
the bracket that holds the actual motor mount(passenger side) has 3 bolts and I had only removed 2 the third bolt is not easily seen because its on the bottom and was difficult to remove I removed it and the bracket came right off...then i just removed the nut holding the actual motor mount removed the old mount replaced with the new mount and then replaced the bracket
Forcedair1
Feb 19, 2020 01:51 PM
Safari
US Central
Sep 21, 2015 09:34 AM
1964Daimler
Sep 9, 2015 11:28 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
XJsc-guy
Sep 2, 2015 11:43 AM
