US Southwest AZ, TX, NM, OK
XJS 1988 v12 power window
Old Oct 27, 2013 | 09:43 AM
nicksa10's Avatar
Default XJS 1988 v12 power window
Drivers side window operates great, passenger side not even a click-click.
Any ideas of where to start looking?
Old Oct 27, 2013 | 09:57 AM
Doug's Avatar
As often as not it's the switch. Swap the left/right switches and see if the problem changes sides.
If it *is* the switch then you might be able to repair the old one. Often they can be carefully pried open and the contacts cleaned. Or sometimes you can spray electrical contact cleaner into the innards of the switch and bring 'em back to life.
If the switch *must* be replaced be selective in what you buy. Buy a genuine Lucas if you can. Some vendors sell a rather chintzy aftermarket replacement which is even worse than the originals and doesn't last. This makes repairing the old one, if possible, a more attractive solution IMHO
Old Nov 20, 2013 | 12:56 PM
jomia092306's Avatar
I tried this and the the switch works. any idea or steps on how can i replace the motor on window...like how to remove panels ?
99xk8guy
May 28, 2024 09:36 PM
1100me
Jul 24, 2023 06:10 PM
mbergen
Oct 23, 2019 10:26 PM
1100me
Sep 7, 2015 06:26 AM
d a
Sep 3, 2015 02:34 AM
