Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
GAZ dampers for '95 XJR ?
Old Apr 29, 2013 | 06:32 AM
JohnXJR6's Avatar
Default GAZ dampers for '95 XJR ?
Dear All, I am saving up for some new dampers for my '95 XJR.
GAZ do adjustable units for the XJ40 and they are used by some of the racers, so should be ok in terms of handling and are reasonably priced at £60-70 each.
Will they fit my X300?
I am sure that the front ones will, but not sure if the rear arms / mounting points are different on the XJ40.
Old Oct 16, 2013 | 08:48 AM
doc's Avatar
doc
I have had an XJ40 and still own a XJR6
I just bought the bilstien oem replacements but the standard shocks on XJR6 cars are green bilstiens I could have reconditioned them it was quicker and cheaper to just buy new bilstiens
Old Oct 17, 2013 | 11:03 AM
JohnXJR6's Avatar
I think the green Bilstiens are about £200 each which is too much for me given the value of my car. I also like the idea of adjustment. Do you recall if the mounting was different on the rear between the xj40 and x300?
Old Oct 18, 2013 | 07:09 AM
doc's Avatar
doc
Same if I remember you could get the original Bilstien reconditioned adjustable shocks aren't going to make much difference
MrWhite
19
Jun 14, 2022 07:49 PM
MrWhite
Oct 1, 2015 01:43 AM
JAMES1944
Sep 29, 2015 11:58 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
Woznaldo
Sep 26, 2015 11:02 AM
