Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
Jaguar Newbie! Wheel size question
Old Sep 16, 2013 | 01:16 PM
John Broski's Avatar
Default Jaguar Newbie! Wheel size question
Hi All! I just gave in to a lifelong desire and bought my first Jaguar... a 1986 XJ6, claret with biscuit interior. Love the car, don't care for the original "Kent" alloy wheels.
My question: Will wheels from a 1991-1993 XJ6 fit my 1986? The current Kents seem to be 15 x 6 inches, 5 bolts on 4.75 inch circle, with 28.5mm offset.
The 91-93 wheels I've found are listed as same bolt pattern, but 15 x 7 inches and 33mm offset.
Think it would work? Would my (decent) 215/70 R15 Pirelli tires fit? The newer wheels are "dignified" rather than "sporty" (like the Kents) and I like them. (My first post here... hope I did it right.)
Thanks,
John
Old Mar 26, 2014 | 05:44 AM
Kay's Avatar
Kay
Hi there,
From what you have told I believe they should fit. I am no expert and hopefully someone that knows more than I do will correct if I am wrong
Kay
Old Mar 29, 2014 | 02:04 PM
Wpapke28's Avatar
I have a similar question, whether the XJS wheels will fit an 86 XJ6?
Bill
Old Apr 2, 2014 | 10:46 PM
Doug's Avatar
I've seen 'em on quite a few Ser III Jags over the years so apparently they do fit.
I've heard that in some case the center cap won't fit, though. The front hibs are a bit too long so the wheel bearing dust cap interferes with the fit of the center cap. I recall that the fix was to space the wheel aboard 1/8" or so.
Others will chime in
Old Apr 2, 2014 | 10:49 PM
Doug's Avatar
Bill
In nearly all cases, or perhaps literally all cases, the answer is yes. But XJSs came with a variety of wheels over the 20 year run so there might be an exception or two.
Which ones are you thinking of?
BrentGardner
29
Dec 16, 2024 12:13 AM
1100me
Aug 27, 2020 11:37 PM
Doberman_Fan
22
Dec 24, 2019 06:21 AM
rvdz
Dec 7, 2019 06:42 AM
Johncy2000
Dec 15, 2015 08:02 PM
