Wheels / Tires, Suspension & handling Wheels and Tires. Discuss sizes, fitments, offsets, profiles etc etc Discuss roll bars, springs, shocks etc for your Jaguar
Looking at new rims - but.....
Old Jan 18, 2014 | 05:03 PM
Veteran: Navy
Default Looking at new rims - but.....
have questions on whether to buy the same size all around or stagger front/rear. What is the benefit of staggered rims? I know costwise, it will increase tire costs over the course of ownership, but is there any real advantage?
I've already picked out the style - going with chrome Coventry Whitley's and looking at 18's.
thoughts/info are appreciated
Old Jan 18, 2014 | 06:10 PM
QuartzSTypeR's Avatar
Staggered allows you to run wider rear tires which helps rear end grip in a straight line as well as reduces oversteer in turns. Plus they look better and if the vehicle was designed for it from the factory I would want to continue getting the best performance out of my vehicle.
Old Jan 18, 2014 | 06:39 PM
Veteran: Navy
Thanks - trying to understand and make an educated decisions. Right not running factory 17s (Lamina's) all around and was looking mainly to dress up the appearance but want to make sure it is not going to screw anything up. When I went for a quote on the Coventry's - they recommended against, but said if I did staggered rims, I could still use all the same tires - which didn't make sense to me.
Old Jan 19, 2014 | 05:56 PM
Veteran: Navy
how do I determine proper offset, center bore and bolt pattern as I found some I am considering.
Old Feb 8, 2014 | 10:48 PM
richzak's Avatar
Remove the front and rear wheels and look at the stamps on the inside for current offsets.
Centerbore is most likely 63.3mm, and bolt pattern is 5 x 108.
This is for the 2008 XK.
Old Feb 9, 2014 | 10:32 AM
Veteran: Navy
Thanks Rich! will look at this week
robbing
Mar 5, 2024 10:51 AM
Larry-Cleveland
Feb 9, 2019 03:17 PM
Marque
Oct 11, 2015 05:59 PM
Marque
Sep 27, 2015 10:28 PM
