Key Socket for Locking wheel nut
Old Jun 14, 2012 | 03:51 PM
bryans's Avatar
Default Key Socket for Locking wheel nut
Just discovered that the Key Socket for Locking wheel nuts has vanished. How will I know which is the right one to buy?
Old Jun 14, 2012 | 04:30 PM
We need some more clues bryans.
Old Jun 15, 2012 | 07:06 AM
bryans's Avatar
I discovered that the key was not there anymore, probably was not put back by mechanic after last service, since I never used it. Mine is a Jaguar X-type 2004 2.0D. Is this key same for all, or there's a some different from others? How shall I proceed, as if I'll need to change a tyre due to a puncture I can't. Basically I can't use the car till I find what to do.
Thanks in advance.
Old Jan 25, 2013 | 04:50 PM
markoscar's Avatar
Same problem here Bryans, im thinking of getting a universal locking wheel nut removal kit of ebay and hoping for the best (unless anyone on here suggests otherwise)
Old Jan 25, 2013 | 05:52 PM
henry k's Avatar
If you have not already done so, may I suggest that readers have a look at their key socket and make a note of the code on it.
Save the code in several places so it cannot be lost. Maybe your phone, service book, email to yourself or a Tattoo?
Here endeth todays lesson.
Sorry bryans and markoscar all I can suggest is you check any documents / user booklet in case it has been noted down somewhere.
The code is a single letter stamped three times in a column on the side of the key.
There are 22 different locking wheel nuts with letter codes from A - Z (except I, O, Q and U)
A Jaguar dealer may have a full set and could take them off for you.
UK dealers seem to either refuse or charge a fortune per wheel.
I have yet to read that anyone has got a spare from a Jaguar dealer in the UK.
The usual approach is we can sell you five locking nuts and a key for approx £100.
Car breakers yards are starting to realise the value of these keys and are now advertising on the UK Ebay.
I would not rush off to do that.
I have read extensively about these £$%$%^&&&* wheel nuts and the news is not good. From what I have read these removers are pretty useless as having smashed or cut off the dome ( which should rotate) there is a not enough material for those type of removers to bite into in order to grip what is left.
Brute force may damage the alloys. Some folks weld a lump of steel onto the part nearest the wheel and go from there.
Others say go to a tire outfit as they can always get them off. I would watch them like a hawk to see their methods.
Me - I guard my key nut and I plan to get Mcgard ( who do supply spares) and of course Mcgard appeared in the 2008 accessories catalogue.
All the 2008/9 cars I have seen in the UK still have the domed sort.
Figure that out!
Old Jan 25, 2013 | 06:23 PM
Jaguar Dealers have access to the full specification on all vehicles. The Locking Wheel Nut Key Number is part of this information.
This is page 3 of 4 of the specification printout for my XK8 from the Jaguar Direct Dealer Warranty system available to all Jaguar Dealers. I've obtained similar printouts for my last four Jaguars. The Key Number is arrowed in red:
There's many reports on the forum of members telephoning or visiting Dealers and being given the Key code number on providing proof of ownership. Once you have the number, Wheel Nut Keys are regularly advertised on eBay etc.
The right approach and attitude can save a lot of time, effort and money.
Old Jan 26, 2013 | 04:20 AM
henry k's Avatar
I am new to Jaguars so this is my first one.
My local main dealer supplied me with such a printout but there is no wheel nut key number on it hence my suggestions.
Yes. Good advice. I suspect that I have read the moans but the good experiences are less reported.
Old Jan 27, 2013 | 07:17 PM
henry k's Avatar
Correction?
When searching Ebay for Land Rover locking wheel nut keys ( which I believe are the same as Jaguar ones) I saw both I & U for sale
I did not see O, Q, X, Y, Z.
Old Apr 11, 2013 | 02:19 AM
copyquality's Avatar
I would suggest from my own experience with a lost key that everybody writes down the code letter or number on the key ideally in the service record. This would help new owners like myself who are not aware what a nightmare a lost key can cause.
Barretts of Canterbury Kent have a full set of the letter keys and are reasonably priced and very helpful. From then I found the key letter and bought a new key on ebay for £20 from SB Wheels
Old Apr 17, 2013 | 02:03 PM
andrac's Avatar
check my recent post
Old Jul 2, 2013 | 04:38 AM
Roger Scales's Avatar
Hi, not only did our local tyre centre break our locking nut key but they also wrung off a wheel nut which only leaves what looks like a washer with absolutely nothing to get hold of. The removal tools on ebay won't do it, the RAC couldn't get them off. Jaguar tried and failed and then wanted to cut the two wheels off.
Finally found someone on the internet Locking Wheel Nuts Removed - from any car every single time, guaranteed. and they had all four off in about 40 minutes which cost me £50.
Hope this helps.
RS
Old Jul 2, 2013 | 07:12 AM
My son just got an X type a few weeks ago.......one of the first things we did was to remove the locking wheel nuts, in fact ALL wheel nuts and bin them.
The issues with Jaguar wheel nuts, in particular the locking wheel nuts is well documented. There's been many an owner stuck / stranded due to this and its caused countless problems.
We removed all the 2 piece nuts & the locking wheel nuts and binned them.
They were replaced with solid 1 piece equivalents easily found on Ebay and were around £20 for the set.
Stolen alloys is more or less a thing of the past, at least not as prevalent today as it was IMO
Perhaps something to consider?
Old Jul 3, 2013 | 05:54 AM
henry k's Avatar
them.
My understanding is that one piece nuts are for steel wheels only
Alloy wheels need two piece nuts that include the washer else alloy wheels can be seriously damaged.
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
XJsc-guy
Nov 23, 2015 01:56 PM
08Z06
Oct 24, 2015 05:46 PM
jagent
Sep 12, 2015 01:40 AM
