OBDII code PO733
Old Sep 1, 2011 | 08:13 PM
railroader7406's Avatar
Default OBDII code PO733
My X Type with 110K miles would shift up through all gears when starting out from a stop, but when brakeing and slowing down it would downshift through the gears , but at the point where it should have been in 3rd gear it would be in neutral. I changed the ATF fluid using the Castrol Special Import and then made sure oil level was proper and still had the problem.
Rotating the elctrical switch on top of the transmission (J gate adjustment?) slightly one way made things worse. When rotating the switch in the opposite dirrection it seemed to drop into a natural detent and the problem was fixed. I now have over 1000 miles on the car since the repair and have not had any problems. You have to remove the battery and battery box to get at this switch. It is directly on top of the transmission and is bolted down with 2 bolts. there is a slot under one of the bolts and when loostened the switch will rotate left and right. I hope this helps someone.
Old Sep 2, 2011 | 02:32 AM
Cadillac's Avatar
Thanks for this topic, good to see it worked for you
Old Sep 2, 2011 | 06:30 AM
Thermo's Avatar
Veteran: Navy
railroader, thanks for the tidbit of information. That is a problem that is fairly unique and I can't say that I have seen it around the forums all that much.
On a side note, which railroad do you model, UP here.
philwarner
Oct 4, 2024 01:37 PM
Bcrary3
Sep 12, 2021 05:41 AM
philwarner
25
Jun 26, 2021 05:43 AM
scooternva
19
Oct 27, 2015 02:14 PM
drgrcr
Sep 25, 2015 10:31 AM
