"howling" from left rear goes away with brakes applied ...
Old Oct 27, 2008 | 04:59 PM
racerx82's Avatar
Default RE: "howling" from left rear goes away with brakes applied ...
I'm guessing wheel bearing here
Old Oct 27, 2008 | 05:05 PM
Thermo's Avatar
Veteran: Navy
I would be leaning towards a wheel bearing too. I get the same sort of indications with my Expedition when the front wheel bearings are starting to go. Straight the noise is barely noticeable, I turn one way the noise goes away, turn the other way and the noise is definitely noticeable.
Old Oct 27, 2008 | 06:55 PM
Dennis's Avatar
ud
Could be a cat's tail caught up in there somewhere too..
I know, I know..Shut up!
Old Oct 27, 2008 | 08:28 PM
christo's Avatar
Not sure how this pertains to the X but in the past I had a rear wheel drive car and the rear was shot. While accelerating the rear end would howl, kind of sounded like a super charger whine?
Old Oct 28, 2008 | 03:18 PM
ken@britishparts.com's Avatar
This is an absolute shoot in the dark, so look out!
We sell a tremendous number of LH rear calipers. I wonder if the piston heats up and expands causing some sort of strange pad wear.
Just an idea.
Old Oct 29, 2008 | 04:52 PM
Let us know how it goes. It's strange; we sell very few RH calipers, but can't hardly keep the LH units in stock.
Old Oct 29, 2008 | 05:37 PM
racerx82's Avatar
Yeah, let us know...i'm curious too!
Old Jun 13, 2017 | 03:53 PM
harley9883's Avatar
Question
I have a 06 s-type. I have the same issue, howling noise from the rear of the car, only noticeable when you traveling over 60mph (noticeably noisier at faster speeds). If I make a sharp right-jerk on the steering wheel, the noise totally disappears. Howl instantly returns when letting go of the right-jerk on the steering wheel. I thought it maybe the right-rear bearing, but neither rear tires have any wobble-play in them. They seem very solid and tight, with no play what-so-ever. Can you have a wheel bearing going out, with no wobble in the hub, what-so-ever?
Any thoughtful hints as to what my problem is would be appreciated.
Forcedair1
Sep 8, 2025 01:57 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
jdzubas
Oct 4, 2015 09:14 AM
KarimPA
Sep 12, 2015 08:15 AM
