02 x type fuel pump???
Old May 13, 2013 | 01:56 PM
louvit's Avatar
Default 02 x type fuel pump???
Is 1000.00 to 1400.00 a correct price for a pump replacement???
Old May 13, 2013 | 05:02 PM
Dr dome's Avatar
Shop on eBay. And see if you can't do it how much a local guy would put it in for you. If you can do it yourself it will take about 4 hours or less.
Old May 13, 2013 | 08:31 PM
DPK's Avatar
DPK
The fuel tank has to be dropped..and actually there is two fuel pumps..
The X has what is called a saddle tank, so one pump transfers fuel from one side to the other, while another pump sends it to the fuel rail on the engine....So the price sounds about right..
Old May 14, 2013 | 05:54 AM
Jac's Avatar
Jac
http://www.jagrepair.com/images/TSB/...stallation.pdf
Looks like a lot of work.
Old May 15, 2013 | 10:04 AM
louvit's Avatar
Originally Posted by Jac
is there a hole under seat cushion to get pump out? this link is to remove tank, Do you have a link to remove pump only? thanks
Old May 15, 2013 | 11:03 AM
Jac's Avatar
Jac
You have to remove the tank.
toronadomike
Jan 22, 2026 10:13 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
Russ Graber
Feb 23, 2019 11:59 AM
bluerdg
Sep 1, 2015 08:07 AM
BigD
Aug 31, 2015 06:13 AM
