02' x type water pump replacement
Old Mar 10, 2009 | 07:32 AM
jag_genius's Avatar
Pretty easy shud take ne one less then an hour . Remove battery then release tension from the tensioner remove belt remove pump .
Old Mar 10, 2009 | 08:48 AM
afonda's Avatar
subscribing.
Old Mar 17, 2009 | 07:24 AM
afonda's Avatar
Default Are there any tricks to the gasket
such as any kinds of spray adhesive or anything?
Old Mar 17, 2009 | 08:38 AM
310jag's Avatar
The only seal you will need is the gasket that comes with the new pump. The removable pump is held to the waterpump housing by about 10 or 12 small (8mm?) bolts. After you remove these (and of course the belt/pulley), it will pry off of the housing. Clean the surface, and put the new one on.
Old Mar 17, 2009 | 08:48 AM
Brutal's Avatar
and for anyone that needs a new one let me know. I have 1 for sale
Old Mar 19, 2009 | 11:11 PM
ruslan35's Avatar
Brutal, I can use a water pump. Please pm me the price. Thanks.
stanjag
Dec 29, 2024 08:26 PM
Xj812
Oct 26, 2015 05:04 AM
celticpiping
Sep 18, 2015 06:17 PM
convincor
Sep 3, 2015 08:03 PM
Calhale
Aug 29, 2015 10:39 AM
