03 X-type engine stall while driving
Old Dec 15, 2011 | 02:03 PM
JoziJag13's Avatar
Unhappy 03 X-type engine stall while driving
Hey I got a customer that came in this morning reporting his engine dieing while at freeway speeds...scary
I checked all the usual suspects like vacuum lines and battery ground from post to body. The customer reported no check engine lights when it happened nor any charging system failure.
I ran it for codes and there is nothing save a p2503 which there is no information on this code on Jaguar GTR. I have researched it further and found that the obdII code is charging system low output if im not mistaken.
I am not a tech but acting like one until my shop finds a worthy tech any advice here would be awesome.
Thanks,
Josiah
Old Dec 15, 2011 | 04:23 PM
JoziJag13's Avatar
I have also tested voltage from the alternator to the positive cable on the battery post. I get 15.2 volts at the alternator and 15.0 at the post when the car first starts. i have checked fuse #82 in the passenger compartment actually i went ahead and tested all fuses in the area and everything checks out there.
BrentGardner
29
Dec 16, 2024 12:13 AM
rvdz
Dec 7, 2019 06:42 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
97xj6lucy
Sep 3, 2015 07:44 AM
Marccutler
Aug 27, 2015 05:11 PM
