03 x-type water pump parts question - pump with housing or just the pump?
Old Apr 1, 2010 | 04:13 PM
AntixSD's Avatar
Default 03 x-type water pump parts question - pump with housing or just the pump?
So the water pump replacement issue is very well documented and I thank you guys for that!
I'm dealing with an 03 x-type 2.5 with 62k on the odo. There is a coolant leak coming from the water pump neighborhood. I haven't had a chance to get in there yet, but I'll update when I do.
My question is regarding the parts. I have been quoted for 2 different parts, one is just the water pump for about $100 and the other is for the pump with the housing. Which one do you guys think I'll need, and how will I be able to determine that once I crack it open?
Thanks guys, don't know what I'd do without you!
Old Apr 2, 2010 | 12:23 AM
myglimk2's Avatar
Just the pump and gasket and you'll be on your way!
myglimk2
Old Apr 2, 2010 | 05:55 AM
AntixSD's Avatar
Great! Would you recommend doing the thermostat at the same time?
Old Apr 3, 2010 | 07:40 AM
myglimk2's Avatar
It wouldn't hurt anything to replace it. Replacing the T-stat will require you getting underneith the car. If the car did not overheat, that repair isn't neccesary.
myglimk2
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
Xj812
Oct 26, 2015 05:04 AM
Calhale
Aug 29, 2015 10:39 AM
