05 x-type code p1000
Old Oct 17, 2017 | 06:27 PM
Warhorse's Avatar
Default 05 x-type code p1000
(Manf cntrl fuel & air metering, auxiliary emission controls) what does it mean? Having problems when I gas the engine to go, it is like cutting the ignition off and on. What is wrong?
Old Oct 18, 2017 | 08:21 AM
avern1's Avatar
The engine cutting out is "limp mode" limiting you to under 3000 RPM to prevent damage to the engine. P1000 is he code for monitor inspections incomplete it would change to P1100 when all inspections are completed.
Are there any other codes?
I don't know where the diagnosis came from but if it is correct the a place to star would be to change the IMT O-Rings. They are the seals for the 2 large round plastic valves at the right hand side of the manifold.
You might want to have the codes read again and then post just the numbers. The generic definitions don't always match the Jaguar definitions.
Old Oct 18, 2017 | 08:39 AM
Alfadude's Avatar
I agree with Avern. Is the problem there all the time or is it intermittent? If it is intermittent that would explain the P1000 code, but there should still be stored codes you can read. Do you have a check engine light on the dash? Could be a vacuum leak and as Avern said the IMT o-rings could be an issue. Another common problem to check is the brake booster check valve and the PCV hose. Could also be intake manifold gaskets, plugs or coils. Best is to get the codes read and post here or do a search on here and chances are you will find an answer on a good place to start looking
Or do you have any flashing lights when the condition is present? If so, don't drive the car as you could be doing damage to teh catalytic converter.
It would also help if you post the details of your car; year, engine size, etc. Helps in diagnosing things quicker.
Old Oct 18, 2017 | 05:26 PM
Warhorse's Avatar
Default Amateur mechanic's helper
Thank you all for helping! We will try all your ideas until we find the fix. I will let you know as soon as I can get back on the computer. I don't get on here very often because so much to do. Catch y'all later.
JimC64
Sep 22, 2025 02:52 PM
KenAdamson
37
May 26, 2020 04:40 AM
smtguy
Jul 26, 2017 02:23 PM
Shivs
Oct 6, 2016 04:18 PM
phreadd
Oct 6, 2016 10:10 AM
