2.5 engine running lean
Old Oct 7, 2019 | 11:11 AM
X-Type Owner's Avatar
Default 2.5 engine running lean
Hello I need help with my car I connected the scan tool to the computer and it says it’s running lean on banks 1 and 2 please help if you had this problem thanx
Old Oct 7, 2019 | 01:15 PM
JagV8's Avatar
There are hundreds of posts about it, with fixes! Go reading...
Old Oct 7, 2019 | 01:43 PM
Alfadude's Avatar
P0171 and P0174? If so, check the IMT O-rings, the brake booster check valve and the PCV hose. Like JagV8 said, search on here for either the codes or the specific pieces I mentioned and you will have a good chance of fixing your problem. If you have different codes than what I mentioned, then post here or do a search for them and you will find a number of good answers. Vacuum leaks are probably the most common cause for lean codes.
JCam
Jul 2, 2018 10:38 AM
1sttimeStype
19
May 15, 2016 07:07 PM
kouichi fujise
Oct 7, 2015 01:33 PM
Popnhol
General Tech Help
Oct 30, 2012 10:31 AM
Engine problem
Aug 23, 2012 04:55 AM
