2001 x Type crank no start
Old Jun 4, 2024 | 11:26 AM
DeadCats77!!'s Avatar
Default 2001 x Type crank no start
Hello big world of techies !
Just joined
couple of things …. Jag x type - 2001 2.5v6
it’s been in a lock up for 2 years while I was away ( working )!
so battery was dead …
opened door with key - fitted new battery and fired cat …. Started then silence ….
now only cranks but won’t fire !
so ….. red light center console - by coin holder …. Not flashing as used too, now on permanently- not flashing just on and red ….
Cat won’t start ….
15 amp fuse - horn keeps blowing too -
keys - both turn to crank and unlock / lock doors - but car won’t fire -
please help if you have any information at all as I’m a bit exhausted .
fuel pump ? Under back seat ….
Car is in v good condition, 34k miles
manuel gear box - looks like a silver cat and I need her back in my life !
help !
god bless and thank you for reading my cat story .
Old Jun 4, 2024 | 03:47 PM
Thermo's Avatar
Veteran: Navy
DeadCats77, from the sounds of things, you have a problem with your instrument cluster. having the red light on in the center console is telling me that you have a security issue and the car is not seeing/recognizing the keys to the car. This is normally because of either a bad instrument cluster or a bad pick up ring around the ignition switch.
Vader714
May 17, 2024 08:17 AM
ellwill
Jun 12, 2021 01:27 PM
Dlaregztif
Mar 28, 2021 03:18 PM
Robh90
Mar 10, 2020 10:22 PM
dgt58
Feb 19, 2016 02:13 PM
