ATF Fill pipe plug replacement
Old Jun 4, 2024 | 02:37 PM
Gdt928's Avatar
Default ATF Fill pipe plug replacement
In need of an ATF Fill Pipe Plug for my 2003 2.5 x-type. Any sources or field expedient replacement ideas? Thanks!
Old Jun 4, 2024 | 03:56 PM
motorcarman's Avatar
The gearbox filler cap (automatic gearbox) is part number C2S12102.
Old Jun 4, 2024 | 04:17 PM
Gdt928's Avatar
Is that a dealer only part?
Old Jun 4, 2024 | 04:55 PM
Dealer part if it is still available.
Used from ebay or salvage yard?
Old Jun 4, 2024 | 05:00 PM
Gdt928's Avatar
Thank you, I'll call dealer first. Any ideas on substitution?
Old Jun 4, 2024 | 05:49 PM
Gdt928's Avatar
Will any tight fitting bung work, or is the cap so designes because it3 subjected to high pressure from the transmission operating?
Old Jun 4, 2024 | 07:28 PM
I used to work on older VWs and the JATCO VW 09A is basically THE SAME.
Maybe the plug will interchange? I don't remember the exact parts so I cannot recommend.
Old Jun 4, 2024 | 09:09 PM
Gdt928's Avatar
Thank you! Those things are hard to source!
Old Jun 5, 2024 | 01:46 AM
Dell Gailey's Avatar
https://partsinn.lt/?oem=C2S12102
Old Jun 5, 2024 | 08:17 AM
Gdt928's Avatar
Thank you Dell, that is good info.
rgp
Aug 8, 2021 04:01 PM
alanroberts50
Jul 17, 2020 02:57 AM
JagQ
Sep 9, 2019 06:49 AM
megacattin
Mar 11, 2019 03:06 PM
plums
Feb 20, 2015 02:52 PM
