2002 Jaguar X-Type 2.5
Old Jul 16, 2016 | 04:35 PM
Drummerbob58's Avatar
Default 2002 Jaguar X-Type 2.5
Is there a sensor that controls AC interior temp. When exterior temp reaches over 100, interior temp goes from cold to hot and back. AC is charged with refrigerant.
Old Jul 16, 2016 | 05:07 PM
Welcome to the forum Drummerbob58,
I've moved your question from General Tech Help to X-Type forum. Members here with the same model will be able to help.
Old Jul 16, 2016 | 05:50 PM
sov211's Avatar
Default AC sensor
Yes, there is a cabin temperature sensor and it is the small aspirator fan unit found behind a small grill on the dash just to the right of the steering column. This fan begins to operate the instant you open the driver's door and remains in operation until 15 minutes or so after the engine is shut off. If you do not hear this fan in operation (the engine does not need to be running) then this could be all or part of the problem.
Old Jul 16, 2016 | 06:44 PM
Default Aspirator fan unit sensor not running.
The aspirator fan is not running, how do you get to this part?
Old Jul 16, 2016 | 08:51 PM
Bud Tender's Avatar
Workshop manual in pdf format.
Jaguar_XType_WorkshopManual.pdf
Old Jul 17, 2016 | 05:53 PM
sov211's Avatar
The aspirator fan ("in-car sensor") is part # C2S 13944, and the cost is about $45 max.
Without this sensor in operation, the climate control is just guessing.
I hope this is helpful.
SickRob
May 31, 2016 11:17 AM
Grrrmachine
May 22, 2016 02:11 AM
harvest14
May 9, 2016 04:44 AM
King Charles
May 5, 2016 12:52 PM
MartianC
Apr 21, 2016 12:52 PM
