2002 Jaguar x-type -air vents/remotes
Old May 24, 2010 | 06:40 AM
The Chris X's Avatar
Try one of the site sponsors for the vents, you can probably get a used set off of a scrapyard X for not much cash. Installation is straightforward, you can do it.
With the remotes, if you do a search of this forum you'll find all kinds of info on them. First off, have you tried a new battery in one of them?
Old May 27, 2010 | 08:45 PM
SimonRage's Avatar
Replacing the remote battery is very easy - try that out first. You *may* need to reprogram them which should take roughly 20 seconds (you probably need to do this if they never worked). There is a guide in the FAQ section for how to do this.
Old May 27, 2010 | 08:52 PM
common problem on the dash vents kirky especially on the older X types. I had similar issues with mine.
There was a redesign on them in the later model years I believe that cured this, so look out for that
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
easylender
Sep 1, 2015 12:56 PM
Dion Petty
Aug 30, 2015 01:00 PM
EastFalk
Aug 29, 2015 08:22 PM
