2002 Window Regulator
Old Jan 10, 2011 | 05:59 PM
Mago304's Avatar
Default 2002 Window Regulator
Hey fellas I have a 2002 X-type and I am looking for a drivers side front window regulator. Does anyone know where I can get one cheaper than $400. I find that to be an outrageous price for something that seems so simple.
Old Jan 10, 2011 | 06:31 PM
sidewalkman's Avatar
Check with the Vendors listed on here, Nalley is one, there are a few but they;ll help you out. We get deals being on this forum. $00 is outrageous.
Old Sep 25, 2011 | 02:36 PM
vtraudt's Avatar
Do you know what is broken? Often, it is the plastic clips.
Typical signs of one broken clip: window moves up only slowly, or even reverses. When starting to move up, a slight 'tilting' can be observed (caused by the glass being lifted only on one side; the tilting leads to binding in the guides).
Also, if 'Guiding' by hand (pushing the glass up) helps (try front or rear of glass and observe), its a strong indicator for one clip broken.
If glass is 'loose' (and be pulled ob or moved or tilted by hand), it may indicate that one or 2 clips are broken.
I have clips for the front and rear X Type windows. PM me.
Old Oct 6, 2011 | 03:07 PM
tokken's Avatar
Hello, do you still have the clips for the front. I need to replace the two on the drivers door of my x-type? Thanks
Old Oct 6, 2011 | 03:17 PM
vtraudt's Avatar
Default Regulator clips for front left
Sure do. Send me an email to info@regulatorfix.com
I can then send you a paypal invoice.
Do you need 1 or 2 clips for front left? I have to check if X Type uses 2x the same clips for each window (but different driver/passenger), or if a "pair" is needed for each window.
-regulatorfix
GordoCatCar
Jan 2, 2017 01:10 PM
Davidvdm
Oct 7, 2015 03:18 PM
srpope80
Sep 23, 2015 09:23 AM
1964Daimler
Sep 9, 2015 11:28 AM
jaguarbill
Sep 5, 2015 11:43 AM
