2002 x-type auto lock issue
Old Jan 18, 2018 | 10:29 AM
vbsummers1's Avatar
Default 2002 x-type auto lock issue
I have read the other posts on this issue, but not sure what direction to go. Key fob auto lock works intermittently. When it goes out, I sit in the car and lock the drivers door which seems to reset, then it seems to work for a while. However, turning the key in the door handle will always unlock the doors, or using the key fob will always unlock the doors. The same happens intermittently when I use the key in the door - always unlocks, but intermittently locks the doors.
I've oiled the key flap door in the ignition switch, but no difference there and it appears to not be closing 100%; I can still see a little space which tells me that may be the issue?
Old Jan 18, 2018 | 03:40 PM
avern1's Avatar
Your assumption is correct. The flap not closing is telling the vehicle your key is in the ignition and doesn't want you let you lock the keys in the car.
Try spraying it with electronic cleaner and then a spray lock lubricant.
Old Jan 18, 2018 | 03:55 PM
vbsummers1's Avatar
Thanks, Vern! I will certainly try that.
Vic
Old Jan 18, 2018 | 04:01 PM
vbsummers1's Avatar
It worked!!
Old Jan 18, 2018 | 06:10 PM
avern1's Avatar
Happy to be of help and glad it resolved your problem.
suavegarve
Mar 13, 2014 05:17 AM
chrismcl06
Sep 29, 2012 12:18 PM
SeldomJAG
Oct 11, 2011 12:21 PM
aggreciv
Feb 25, 2011 09:44 AM
