2002 2.5 V6 Possible Auto Gearbox Issue
Old Mar 8, 2014 | 08:43 AM
suavegarve's Avatar
Default 2002 2.5 V6 Possible Auto Gearbox Issue
I have a 2002 automatic 2.5 V6, and I'm looking for some help with what I believe is a gearbox issue.
The car idles perfectly and when revved up there are no issues or noise, so I believe the engine itself is fine.
When I drive the car I am unable to get hardly any speed, like 5mph and I don't think it changes up the gears. There is also noise coming from the car although I can't determine exactly where, I can describe it as a clunky knocking and grinding noise. This only happens when the car is moving, if it's stationary and in gear the noise is not there.
Any help or advice would be greatly appreciated.
Thank you
Old Mar 12, 2014 | 07:37 AM
suavegarve's Avatar
Tried adding ATF, no different. Any help guys?
Old Mar 12, 2014 | 09:48 AM
mikesmith2's Avatar
Could it be a problem with the transfer box?
Old Mar 12, 2014 | 11:15 AM
suavegarve's Avatar
Is there any way of determining this? I've seen posts about wheel bearings too
Old Mar 12, 2014 | 11:37 AM
mikesmith2's Avatar
Wheel bearings don't restrict your speed so I don't think it's that.
Old Mar 12, 2014 | 05:22 PM
suavegarve's Avatar
Is there anything I can do myself to try and determine the problem.
Old Mar 12, 2014 | 05:27 PM
blackcat2003's Avatar
I'm very sorry to say that I think you will be needing a transmission rebuild.
What happens if you give it a bit of gas with your foot hard on the brakes?
Old Mar 12, 2014 | 06:58 PM
suavegarve's Avatar
If I push the gas it drives but very slowly and clunky. Some dull grinding noises too.
Old Mar 12, 2014 | 07:08 PM
suavegarve's Avatar
I'll have to try with the brake on. I'll report back in the morning sir
Old Mar 13, 2014 | 02:46 AM
suavegarve's Avatar
So I tried with the footbrake pressed and there doesn't seem to be the noise. Could a brake be jammed or something?
Old Mar 13, 2014 | 03:56 AM
mikesmith2's Avatar
It is possible the brakes have jammed.
You could jack the car up an with the handbrake off, gear selector in N and suitably chocked then try turning the wheels by hand, they should turn easily.
Do you use the handbrake very often?
Old Mar 13, 2014 | 05:17 AM
suavegarve's Avatar
Is this something that would have happened while the car was moving. I'm pretty sure it happened as I was braking to make a turn?
jaggedy
Nov 20, 2022 12:09 PM
JCam
Oct 23, 2016 08:27 PM
gunlocators
Sep 30, 2015 08:05 AM
jjmiah217
Sep 28, 2015 09:09 AM
tassiejag
Sep 24, 2015 08:43 PM
