2002 X type rear stabilizer
Old Feb 2, 2015 | 06:10 PM
rayce's Avatar
Default 2002 X type rear stabilizer
I am thinking of tackling the rear stabilizer bushings and links. What will I be getting myself into with this job? Is it just a straight forward unbolt and rebolt?
Old Feb 2, 2015 | 06:51 PM
Thermo's Avatar
Veteran: Navy
rayce, it is a very easy thing to do. Your biggest problem will be getting the nuts loose. So, start now and spray the nuts every day to help get them loosened up. But, after that, things are really straight forward.
Old Feb 2, 2015 | 09:45 PM
rayce's Avatar
Default none
Thanks Thermo. May go ahead and replace the shocks while I'm at it. It doesn't seem like the last owners had kept up the maintenance on this vehicle. When I had the rear Cat replaced, they checked over the car and gave me a laundry list(all undercar). I'm not sure how long I am going to keep this one, but the more I drive it and get things fixed, the more I like it. 150,000 miles and still runs great.
Old Feb 3, 2015 | 12:32 PM
Thermo's Avatar
Veteran: Navy
rayce, if you are down there, might as well. They are simple enough to replace. Remove the 18mm bolt on the bottom and then remove the two 10mm nuts at the top of the shock. Then the shock should fall out of the car. I think your biggest problem will be getting the lower bolt free. You do that, the rest is very simple.
Just for reference, your car came from the factory with Bilstien Comfort Ride shocks. If you do some looking, you now have 3 options for what you want to put back in. You have the Comfort Ride, Sport, and Heavy duty. The sports are going to be slightly stiffer than the comfort rides and the heavy duty shocks are going to be stiffer yet. So, what you go with is up to you. Price may be a driving factor as the heavy duty shocks do cost a fair bit more compared to the Comfort and Sport shocks.
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
Rusty1952
Sep 1, 2015 05:45 AM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
