2002 x-type starting issue
Old Oct 15, 2009 | 03:32 PM
Thermo's Avatar
Veteran: Navy
29 rdstr, when you say the car will not start, are you saying that when in the START position, the engine turns over but will not fire, or are you saying that the engine will not rotate at all?
If you are saying that it is not rotating at all, then I would be looking at either a bad starter or a bad cable between the starter and battery. If you need more help than this, let me know.
If the motor will rotate but will not fire, then the first thing I would do is install a fuel pressure gauge and see what pressure you are getting on the fuel line. With the ignition in the RUN position and the engine not turning, the gauge should be reading between 40 and 50 psig. If the motor does run, then it will drop to around 30-40 psig. If you are not getting these pressures, then you are looking at most likely a bad fuel pump. Let me know and we can give you some more checks to do to confirm a bad fuel pump. If you are getting these pressures, then you are most likely looking at a spark issue. Based on the setup, you are most likely looking at something associated with the ECM. Let me know and we will give you some checks to do.
toronadomike
Jan 22, 2026 10:13 PM
SD96XJ6L
Jan 12, 2022 04:30 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Drew2006
Nov 24, 2015 11:14 AM
tberg
Sep 7, 2015 07:32 AM
