2002 X Type Whirling noise from front end
Old Jan 31, 2007 | 09:52 PM
vaccaro81's Avatar
Default 2002 X Type Whirling noise from front end
I have a 2002 X type that has developed a whirling noise from the front end when the outside temperature is very cold. Its almost like a moan similar to when you run wet fingers around the edge of a glass. It only happens at low speeds when excellerating from a stop and goes away after a short distance. Once car has travelled for a time the noise does not come back. I have noticed that the noise seems to happen more often when making a turn from a stop. Anyone have a similar problem? The car is now out of warranty. Is there a known TSB for this problem? I heard from one source that it might be the drive shaft.
Old Jan 31, 2007 | 09:55 PM
Default RE: 2002 X Type Whirling noise from front end
Hi Vaccaro,
By the sound of it I have a similar problem on my X I think. Only happens now n again though and as you say goes away after a short distance. I have also had feedback that it may be the driveshaft.
Jim C
Old Jan 31, 2007 | 10:01 PM
vaccaro81's Avatar
Hi Jim C
So what did you do about it? Anything?
Old Jan 31, 2007 | 10:47 PM
Nothing as yet Vaccaro..........seems to be running fine at the moment and only happens once in a while. I will get it checked soon though 4 sure
JC
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
h4wk
Nov 27, 2015 05:10 PM
jdzubas
Oct 4, 2015 09:14 AM
timm525
Aug 29, 2015 04:49 PM
