2003,3.0 jaguar xtype battery light
Old Jul 20, 2014 | 03:03 PM
syctv's Avatar
Default 2003,3.0 jaguar xtype battery light
Hi guys,
My jaguar always lights up the battery warning but I have no ideas to find out the reasons.
Here's my situation:
If the car's temperature is cool, the battery light will burn if I use my air-condition while I just started the engine. But it won't lights when I use air-condition after I have driven for few meters or minutes later.
Second, if the car's temperature is normal it will light up when I restarted the engine. And I think it won't charge since the lights shows up.
I already changed battery and it's cable. I also replaced a new dynamo few days ago and it doesn't work. I still saw the light.
Hope you guys can let me know how to solve the situation like this.
Mike
Old Jul 20, 2014 | 04:21 PM
Bud Tender's Avatar
You say: I already changed battery and it's cable.
Which cable? The ground cable can cause problems, maybe more so than the positive.
Old Jul 21, 2014 | 06:46 AM
syctv's Avatar
Thank you for the reply,
I replaced my positive cable and the problem disapeard for few days.
But after those days, the same situation showed up.
Therefore, I will check my ground cable.
If the ground cable is fine, does anything else causes the problem?
Old Jul 21, 2014 | 06:05 PM
dennis black's Avatar
may be your ALTERNATOR is dying
hafren
Aug 30, 2023 03:42 PM
Jandreu
Aug 29, 2015 07:31 PM
Tony Bow
Aug 28, 2015 05:17 AM
Andrew McVey
16
Aug 27, 2015 07:21 PM
Terrance Williams
Aug 26, 2015 11:50 AM
