2003 jag x type 3.0
Old 07-19-2014, 08:56 PM
flyguychrisw's Avatar
Default 2003 jag x type 3.0
I have a 2003 jag x type. When I put it in drive it takes off and when I put it in neutral it returns to normal idle.im having to drive it this way. engine light is on. I have lo v for switch code on 02 bank 1 sensor 2 and bank 2 sensor2.need your help.
Old 07-19-2014, 11:18 PM
Diavolo's Avatar
what do you mean by "takes off" in drive?
sounds like an air leak?
maybe this will have some helpful knowledge:
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
do you know what code is making the check engine light come on?
Old 07-20-2014, 12:21 AM
when I start the car it idles high then slowly comes down to a nor mal idle .I put in drive and accelerate and the car takes off at a high rpm.i have code p1000 and I think p0057 02heated sensor low v bank 2 or something like that. Could my 02 sensor cause high then low idle and surges in acceleration
johanasu
09-03-2015 12:39 PM
stanjag
08-30-2015 10:35 AM
EastFalk
08-29-2015 08:22 PM
kesslari
08-27-2015 06:26 AM
Terrance Williams
08-26-2015 11:50 AM
Quick Reply: 2003 jag x type 3.0
