2003 X-Type 2.5
Old Jan 25, 2020 | 12:50 PM
micmee1's Avatar
Default 2003 X-Type 2.5
Idles rough at start, but runs fine once she comes up to temp. Engine light is on, and throwing out codes P0171, P0174, P0300, P0302 PO305, then P0133 and P0153. Bank 1 Sensor 1 was replaced a year or so ago. Do we need to change all 02 sensors, or is there something else we need to look at? Many Thanks
Old Jan 25, 2020 | 02:37 PM
Originally Posted by micmee1
..... or is there something else we need to look at? .....
YES - advice from members with the same model.
I've moved your question from General Tech Help to X-Type forum.
Old Jan 25, 2020 | 02:43 PM
micmee1's Avatar
many thanks
Old Jan 25, 2020 | 07:06 PM
Dell Gailey's Avatar
Check the "big 3" for vacuum leaks. SEARCH here for the 171 & 174 codes for guidance.
Also with the P0300 (generic misfire code) P0302 (cylinder 2) & P0305 (cylinder 5) if the big 3 are not a leak problem, you probably have an intake gasket leak.
Old Jan 25, 2020 | 07:15 PM
micmee1's Avatar
Many thanks.... Still not quite understanding why the rough idle during a cold start, then seems to run fine. We have sensors on hand, and we are in the process of changing them out. Went ahead and changed the battery since it was out and 3+ years old. Here's hoping. Again, thank you. M
Old Jan 25, 2020 | 07:18 PM
Expansion of the motor (getting hot) metal parts sealing the air leak...
benpearce2013
Nov 19, 2016 09:42 PM
jagEST
Oct 24, 2015 11:11 AM
kevintbaldwin
Sep 21, 2013 10:08 PM
JADCV
Jan 27, 2011 04:56 PM
afbcamaro
Oct 7, 2007 10:11 PM
