2003 X-type 3.0L Gas Pedal,Please Help!!
Old Jul 4, 2015 | 12:56 PM
William E. Parks's Avatar
Default 2003 X-type 3.0L Gas Pedal,Please Help!!
I have a 03 x-type 3.0L 5 speed.. I was driving along and all of a sudden the car would not accelerate, engine idles somewhat rough. Accelerator pedal goes to floor. I have replaced the pedal assembly, but no results. Can anyone help?
Bill Parks
Marr, Ohio
740-934-2224
billparksgarage@monroecty.net
Old Jul 5, 2015 | 10:01 AM
heybeck's Avatar
Hi, My XJ8 did exactly the same, turned out to be the fuel pump. Don't know about the X-type but the XJ8 has a Schroeder valve at the top of the engine, same as a tyre valve. Press the valve pin and fuel should spurt out. Worth a check.
Good luck
Old Jul 5, 2015 | 07:33 PM
Good luck
Thanks, but my problem lies somewhere in the throttle body/electrical. The accelerator is electrical and is not moving the throttle plate. Some say t.p.s. others t.b. motor. I could replace the entire throttle body assembly, but very expensive. Surely some one has ran into this problem. Thanks again for your thoughts.
Old Jul 6, 2015 | 01:13 PM
DPK's Avatar
DPK
Sounds like it maybe the throttle-body...
New one here is the cheapest I've found...also you may need a couple of gaskets too and an ECU re-flash..
Fuel Injection Throttle Body OE Supplier Fits 02 04 Jaguar x Type 3 0L V6 | eBay
Shawn Svacha
Nov 4, 2019 02:47 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
Ipc838
Sep 13, 2015 03:27 PM
Darren Schermuly
Sep 11, 2015 07:55 PM
joseph1945
Sep 5, 2015 07:12 PM
