2003 X-TYPE High Beam Light Problem
Old Sep 5, 2013 | 12:25 PM
dmanjar60's Avatar
Default 2003 X-TYPE High Beam Light Problem
When I turn on my head lamp, the High beam always stays on, I cannot turn back down to normal beams,,,help
Old Sep 5, 2013 | 03:17 PM
Thermo's Avatar
Veteran: Navy
dman, odds are, your turn signal stalk is toast and you will need to replace it. Granted, I would assume you have pulled the lever towards you to remove the headlights off of the high beam. If you want to use a multimeter to figure out what is going on, let me know and I will assist however I can. Atleast for the moment, you can make sure the high beams do not come on as you can remove the main beam/fog light relay and that will kill power to the high beams.
Old Sep 5, 2013 | 09:48 PM
AlfaVeloce's Avatar
I had a blown fuse cause this on our car when we first bought it. I don't recall which fuse it was. It was one under the hood.
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
johanasu
Sep 3, 2015 12:39 PM
kesslari
Aug 31, 2015 04:53 AM
gene1
Aug 27, 2015 08:56 PM
