2004 with major squeeks and scratching
Old Mar 24, 2008 | 10:47 PM
Default RE: 2004 with major squeeks and scratching
Size:  6.3 KBName:  X6JYMSAAB5.jpg
Size:  6.1 KBName:  AudiX6JYM-2.jpg
Welcome to the forum hawaiian.............
Re your post......Firstly, its considered good manners to introduce yourself and your vehicle in the new members section before diving in.
Secondly, from your post, as you haven't said, I assume that you own an XJ. Is that correct?
Please fill us in a little.............If thats the case the post is in totally the wrong section and needs to be moved to either the XJ section or possibly General tech help.
Please respond
Jim
Old Mar 24, 2008 | 11:59 PM
jvegas's Avatar
a 2004 what? miles? package? who did the work? what was replaced? has it done this from day 1? we need more details to help. fill us in.
Old Mar 26, 2008 | 05:18 PM
mr.xtype's Avatar
Well sounds like your caliper unit may have been bent. Did you notice your pads or disk on the affected side chewed up? also check to see if your wheel is rubbing anywhere in your wheel well, if this is the case chances are you something slightly bent, might be better off getting a new front corner assembly. When this happened to me, I changed pieces one by one which was expensive. It was much easier to buy the whole new strut, spindle, caliper, breaks, tie rods ets.. If your wheel is rubbing make sure u get it fixed asap or your tire will wear un evenly.
Old Mar 26, 2008 | 06:44 PM
jag_genius's Avatar
also when the caliper and carrier touch the rotor.. especially on turns i have seen body shops leave the axle nut loose causing the carrier to move and touch the rotor.. scrap yard maybe.. from dealer very expensive..
Old Mar 26, 2008 | 08:10 PM
jagxtype's Avatar
i bet your caliper spliding pins are bent is why its only touching one side. All that pressure could very well have caused the crack as well.
Old Mar 26, 2008 | 08:44 PM
Dennis's Avatar
ud
Check out this place and compare to dealer's prices, they are about 1/2 theprice of the dealer's
After clicking on BRAKES type in the word Caliper
http://www.trademotion.com/partlocat...model=X%2Dtype
caliper, x-type, right
02-06
$442.00
$0.00
$331.50
Brakes - Hydraulic system - Front brakes - caliper
MrWhite
19
Jun 14, 2022 07:49 PM
LnrB
Oct 13, 2015 12:45 AM
waynepaulj
Oct 2, 2015 04:05 PM
MrWhite
Oct 1, 2015 01:43 AM
millertic
Sep 30, 2015 08:11 PM
