2004 x type won't start
Old Apr 18, 2014 | 08:51 PM
dapac9's Avatar
Default 2004 x type won't start
Hi, I have a 2004 jag x type 3.0 bought few months back, it was running fine until yesterday,i stopped for an errand when I came back car would not start, would not even crank, put it thru a snap-on computer came back with the following codes B1600,B1601,B1681,B1213,B1357,B1205,B1202,C1922,C1 924,I tried to get the key fob reprogrammed was told that the problem was not with the key it could be the engine immobilizer or an electrical short. Does anybody have any idea how I could solve this problem,taking it to the dealer is not an option since the car won't start and the tow cost to the nearest dealer prohibitive. Would appreciate any help. thanks... Also, does anybody know any good jaguar mechanic in Queens, New York?
Old Apr 19, 2014 | 12:07 AM
Cherry_560sel's Avatar
Have you tried putting it in park.
Old Apr 19, 2014 | 07:59 AM
dapac9 - welcome to the forum. I've moved your thread from the General Tech Help to the X-Type section for greater visibility.
As this is your first post, also recommend you stop by the New Member area and post an intro. There you will also get info on navigating the forum
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Apr 19, 2014 | 08:46 AM
dapac9's Avatar
An idiot on the loose trying desperately to be funny, it's a pity, you find them everywhere...l.o.l...
Old Apr 20, 2014 | 09:51 AM
Good luck with that no start problem my friend ,...oh and btw...that means "by the way"..... sometimes the shifter assembly goes out, so since our cars are fly-by-wire...(that means no actual mechanism moving a lever connected to the transmission) and your car was running prior to the no start issue....then my suggestion, although comical, is actually valid.
1964Daimler
Sep 2, 2015 11:41 PM
Rusty1952
Sep 1, 2015 05:45 AM
EastFalk
Aug 29, 2015 08:22 PM
Drew2006
Aug 28, 2015 04:22 PM
Aegis21
Aug 27, 2015 08:30 AM
