2005 X-Type VDP
Old Feb 3, 2011 | 12:32 PM
pnclopez's Avatar
Default 2005 X-Type VDP
I have a issue with my hightlights not turning off. I sometimes have to keep turning the light knob on and off for a few minutes before they with turn off. Some days I have no issues and they turn off right away. When I turn the light switch to the off position all other lights turn off issues is with the headlights only, thanks.
Old Feb 3, 2011 | 02:27 PM
Thermo's Avatar
Veteran: Navy
Let me look at the drawings for your car and I will see what I can find out for you. Should be pretty straight forward.
Old Feb 3, 2011 | 05:07 PM
Thermo's Avatar
Veteran: Navy
PNC, we are going to try a few things here. First, this will need to be done when the lights will not turn off. So, once you meet this condition, follow these few steps.
First, open up the hood and remove relay R11 from the fuse box. Do the lights go out at this point. If no, then you have a wiring problem under the hood. If yes, then continue.
Using a multimeter and looking at the diagram on the fuse, do a resistance check between pins 3 and 5 of the relay. Do you get 0 ohms or infinite ohms. If you get 0 ohms, then the relay is bad, you need a new relay. If you get infinite ohms, you either have a wiring problem in the dash of the car (further troubleshooting will be required) or you managed to cause the relay to change state as you pulled it out. Replace the relay to confirm that the headlights are still coming on with the new relay. If so, this confirms a wiring problem under the dash. If not, then you fixed the problem.
If you need more info, let me know. I will do what I can.
Old Feb 3, 2011 | 05:20 PM
pnclopez's Avatar
Thermo, thanks. I will try the next time the lights do not turn off and will let you know what the end result is. Thanks again.
aholbro1
Dec 29, 2024 06:46 PM
perezal
Dec 24, 2015 04:16 PM
James007
Oct 3, 2015 03:29 PM
Douglas Murrell
Sep 14, 2015 07:47 PM
laserguy
Sep 3, 2015 02:02 PM
