2025 Headlight upgrades
Old Feb 15, 2025 | 10:35 AM
Thermo's Avatar
Veteran: Navy
NYC, If you remove the headlight housing, there is a bolt under the headlight. Loosen it, slide the ground for the ballast there using a ring lug. I want to say that right next to the ground spot was a nice flat area for you to double side tape the ballast to. Worst case, a few zip ties and it will go on the side of the frame support right there.
As for drilling the hole in the headlight covers, I used a step drill bit and I want to say it was the 3/4" step that fits the grommet. Measure yours just to make sure.
Adam Lueb
Dec 29, 2022 12:07 PM
max224
Jul 13, 2021 12:22 PM
3timejag
Jul 7, 2019 12:24 AM
BritCars
Mar 6, 2019 10:59 AM
FirstTimer
XJ40 ( XJ81 )
Oct 7, 2009 08:15 AM
