3 doors unlock problem RESOLVED
Old Aug 22, 2012 | 05:02 AM
spooler's Avatar
Default 3 doors unlock problem RESOLVED
Hello,
I'm newbie here! I own Jaguar X-Type 2005 and i have problem with doors unlocking:
When i press lock on remote, i hear click sound on all doors, but when i want to unlock opens just drivers door and trunk. All another doors can't be opened from inside (can't pull clip) and outside. I tried to push open button twice on remote but still don't work. Also i tried to push both buttons for 4sec to change lock from double to single, it's changed, but still nothing happened.
There was few mystery times that doors worked properly and several times when doors opened just from inside (unlock clips was working).
Any ideas? Is there electronical or mechanical problem?
Thank you in advance!
Old Aug 22, 2012 | 08:02 AM
pab's Avatar
pab
On my '05 3L if I push the unlock button on the remote once it unlocks only the driver's door. However, if I push it again it unlocks the other three.
Jaguar: Grace, Pace, and Space - Sir William Lyons
Old Aug 22, 2012 | 08:44 AM
spooler's Avatar
Yes, it should be like that but it doesn't work to me. With the key is the same.. I can unlock just driver's door and trunk. I guess if that would be mechanical problem then one of the door won't work, but not all 3.
Old Aug 22, 2012 | 03:34 PM
Thermo's Avatar
Veteran: Navy
spooler, from the sounds of things, it is a problem with the GEM getting the signal from the keyfob. I would first start off with standing in a single spot where you know the car is receiving the signal (lock/unlock the driver's door a few times). From this location, attempt to lock all 4 doors. Did they all 4 click? If yes, then attempt to unlock all 4 doors. if you only get 1 click (ie, driver's door), then you most likely have a problem with the driver's door lock position switch. The GEM is set up to sense when a door lock starts to move and will then start actuating the next door. The sequence is driver's front, passenger front, driver's rear, passenger rear.
Hope this helps some.
Old Aug 22, 2012 | 11:58 PM
spooler's Avatar
Thank You Thermo for your detailed answer!
Yes, when locking click all 4 doors, but when trying to unlock clicks and unlocks just driver's door.
What would be the solution? Is it possible to fix GEM or it needs to be replaced?
Old Aug 23, 2012 | 12:48 AM
spooler's Avatar
Guess what? I solved the problem!
I tried to push all doors lock clips to "lock" position and miracle - doors working properly!
I think one of the doors lock was between lock/unlock position.
Old Aug 23, 2012 | 03:34 PM
Thermo's Avatar
Veteran: Navy
spooler, odds are it was either the driver's door (most likely since it sees the most use) or the front passenger door. It is a known problem with our cars that the driver's door will have the cable stick that drives the door lock button.
Old Aug 24, 2012 | 05:59 AM
spooler's Avatar
I thought that i solved the problem, but today happaned same thing. I tried to do what i done yesterday, but nothing changed. It seems that problem is more difficult than i thought. It happened when passanger got out of the car and then i lock, but when i tried to unlock, unlocked just driver's door...
Do you any suggestions? Is it possible that there is problems with GEM?
Old Aug 24, 2012 | 04:03 PM
Thermo's Avatar
Veteran: Navy
spooler, to have a problem in the GEM module that would not affect the driver's door would require multiple failures at the same time. odds are, you are looking at the driver's door latch mechanism giving you all of your troubles.
Old Jun 6, 2013 | 09:26 AM
frychef's Avatar
I've got this same exact problem on the same year and model. I replaced both doors on the driver's side due to collision damage, but the problem persists. It looks like spooler's problem has been resolved, but I'm not clear what resolved it.
Would my problem be the latch in the passenger's door?
If so, how can I prove it before replacing any parts?
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
Wolfy
May 28, 2024 08:06 AM
Dz1rfj
Jul 17, 2018 10:29 AM
obwoodie
Sep 3, 2015 07:45 PM
