50K mile service?
Old Apr 21, 2009 | 11:20 AM
jjones91's Avatar
Default 50K mile service?
I know it's been asked but couldn't find it.
Is there a 50K Mile specific service? What needs to be done at this mileage?
Old Apr 21, 2009 | 07:51 PM
Thermo's Avatar
Veteran: Navy
jjones, according to the JTIS CD, all it says to do is change the oil, top off all the fluids, check for leaks, inspect the brake pads for wear(replace as necessary), and inspect the belts and wipers.
With that being said, it also says at 5 years you should swap out the coolant. Since you are at 4+ years, might be a good time to do that. Probably a good time to also swap out the fluid in the differential and transfer case. Rear differential probably wouldn't need it, but the transfer case definitely. This would probably be a good time to rotate tires as it is on a nice even number to keep track of tire rotation with.
Old Apr 22, 2009 | 09:40 AM
jjones91's Avatar
Perfect, thanks. Just got new brakes. New tires 3000 miles ago. So sounds like I"m good to go. I'll check into those fluid swaps.
Old Apr 22, 2009 | 10:43 AM
The Chris X's Avatar
Did you swap out the brake fluid when the brakes were done? At the 4 year mark it wouldn't hurt to do that as well, and it's a pretty easy job.
bamforp
Aug 14, 2024 05:36 PM
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
08Z06
Oct 24, 2015 05:46 PM
SteveSheldon
UK & Eire
Sep 8, 2015 11:22 AM
Numwen
Sep 6, 2015 12:30 AM
