abtt light
Old Jan 8, 2016 | 06:06 AM
stupots's Avatar
Default abtt light
I have problems with the battery light coming on some times .came on this morning again, got meter out across battery charging at 14.47 volts ,engine off 12.30 volts , some time it flashes ,some stop on for a few minutes ,then it stop off for a couple of weeks any ideas
thanks
stu
Old Jan 8, 2016 | 07:10 AM
avern1's Avatar
Clean and polish the battery cable connections. Also check the cable connectors for corrosion and fraying. You are getting high resistance under a load. To be sure next time the light is on put your hand near the cable/battery posts. You will probably find they are to hot to touch.
If it continues after cleaning then you are faced with a failing cable.
Larry-Cleveland
Apr 29, 2024 04:58 AM
shl1980
Jun 2, 2016 06:50 AM
caldercay
Jan 14, 2016 06:26 PM
Lawrence
XJ40 ( XJ81 )
25
Jan 14, 2016 12:22 PM
JonWat
Jan 4, 2016 09:06 AM
