Advise on ignition coil replacement for '02 2.5L
Old 04-02-2020, 04:14 PM
Jag4's Avatar
Default Advise on ignition coil replacement for '02 2.5L
Hello forum,
It's time to replace the plugs and I am thinking about replacing the coils while they are in there. I have seen various threads when folks stressed the need for EO parts and where to get them. OE parts were stressed because folks were having trouble with the results - apparently some had more problem than when they started.
Is there some voodoo here that I should know about before ordering these parts?
Ignition Coil - Jaguar (C2S42673)
https://www.jaguarparts.com/oem-parts/jaguar-ignition-coil-c2s42673?c=Zz1lbGVjdHJpY2FsJnM9aWduaXRpb24tc3lzdGV tJmw9MSZuPVNlYXJjaCBSZXN1bHRzJmE9amFndWFyJm89eC10e XBlJnk9MjAwMiZ0PWJhc2UmZT0yLTVsLXY2LWdhcw%3D%3D
Thank you for any insight.
Chris
Old 04-03-2020, 03:15 AM
JagV8's Avatar
Received 4,488 Likes on 3,905 Posts
If they're working now and if there was easy access to all coils I'd get one good spare and just keep using the old ones.
Where access to some is awkward (like under a manifold) I'd maybe buy N (here, probably 3) and swap them in but keep the old ones just in case. Then if one of the remaining old ones fails I'd use one of those spares.
Depends a bit how much you hate doing work!
Old 04-03-2020, 12:31 PM
Jag4's Avatar
Hi JagV8: Thanks!
graham11
03-25-2020 11:42 AM
Iconoclast
07-17-2018 06:14 AM
EZDriver
03-11-2018 07:46 PM
bliving7
09-17-2012 09:32 AM
Quick Reply: Advise on ignition coil replacement for '02 2.5L
