After Market Transmission Cooler
I have an x type Jag with a 2.1 auto 2005 Se
I live in Queensland where the climate is hot. Every car I have owned I always put an aftermarket transmission cooler on it. One car I put a magnefine in line transmission filter where you could not change the filter like the X type. I intend to do this also.
Has anybody put an aftermarket transmission cooler on their X type? If so what size, brand did you use?
Thanks in advance
Thanks in advance
Dell, his question is more around he knows that there is a cooler, but itis not sufficient for his environment. So, what have other people installed.
Sleeperau, I would think that if you say double the cooling surface, that should be sufficient. The trick is keeping the tranny temp under 160F. Above that, tranny wear starts to rise at a very dramatic rate with every 10F change. BUt, under 160F, you can drive the tranny just about forever. So, you may want to see what what the inlet and outlet temps are and then guage a size tranny cooler on that. I think whatever you do, you are going to be one of the first to do it. so, it will be a lot of experimentation and fabrication. Maybe you can find one that is roughly the same length, but go 2 or 3 times taller to get the added cooling area. This should make for atleast half the mounts being the same.
Hi,
i live in Noosa and my 05 3l is just fine. Unless you plan on towing something I don't think you need to spend the money . Very important to change the auto oil and flush the system with new oil.
David Bruce.
David Bruce.
I live in Queensland where the climate is hot. Every car I have owned I always put an aftermarket transmission cooler on it, similar to upgrades people do with a 6.7 powerstroke transmission cooler. One car I put a magnefine in line transmission filter where you could not change the filter like the X type. I intend to do this also.
Thanks in advance
Thanks in advance
anindyam
Dec 15, 2015 12:37 AM
jackra_1
Jun 13, 2015 06:53 PM
05StrJag
Nov 29, 2011 08:10 AM
