Alternator/Battery Cable Problem
Old Apr 19, 2012 | 12:07 AM
ez53436's Avatar
Exclamation Alternator/Battery Cable Problem
Hi guys,
A few weeks ago, I had the alternator light go on and then go away. Today, I was driving the X-Type and went to park, shifted into park and the car turned off. I turned the key to start it up again, nothing. Battery wouldn't even turn on. No ticking from the starter, either.
I tried jumping the battery with my friend's honda civic, but that didn't work. It let me turn on the battery and the car was ticking when I tried to start it, but never actually started. I then successfully jumped it with a Jag XJ8L. I let the car run for probably near half an hour and then I drove it home, trying to use as little electricity as possible. I got home and turned off the car. I turned it back on and it started right back up, without the battery light showing up.
I noticed a lot of white corrosion around the negative battery terminal so I cleaned it with some baking soda and water and it all went away. The car is starting back up.
I'm afraid of driving it on the daily commute because I don't want it to suddenly stop completely in the middle of a 45 zone or something.
Do you guys think it's the alternator or the more commonly problematic battery cables? And do you guys think I should have it checked out by a shop or just drive it while it's working and hope for the best?
Thanks in advance!
Old Apr 19, 2012 | 12:39 AM
Bruce in North Dakota's Avatar
From: That Rectangular Hole in the Consciousness of America
You actually found the problem, there is just another step you need to take to effect a reliable, long lasting repair: Remove and Clean the Cables, and Battery Posts!
Simple job!
Nice instructional video here!
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
mbergen
Oct 23, 2019 10:26 PM
fingers
General Tech Help
Oct 21, 2015 02:02 AM
Richard_gib
Sep 12, 2015 07:08 PM
