Another X-Type Rumble question!
Old Aug 10, 2013 | 06:23 PM
Tumbleweed's Avatar
Banned
Default Another X-Type Rumble question!
My 04 2.5l 5 spd X-type is doing the rumble when decelerating from 70 to 50. It feels like it's coming from the driveshaft area.
I had the car on a lift at the mechanic's place this morning, and what we found is a worn out transfer case mount (the dogbone). When the mechanic shook the driveshaft to show me how screwed up the mount is, all I could see was the driveshaft to transfer case flange moving from side to side, about 1/16 of an inch of play.
How much play is acceptable there?
I bought a new dogbone on ebay, will grease the center bearing, and we're going o change the fluid this week once the dogbone comes in...
thanks!
Al
Houston
Old Aug 10, 2013 | 07:19 PM
Thermo's Avatar
Veteran: Navy
Tumbleweed, if you can see movement in the driveshaft, that is too much movement. The spec is something like 0.030" (or 1/32").
Old Sep 3, 2013 | 08:34 PM
Tumbleweed's Avatar
Banned
we replaced the driveshaft and the dogbone, the rumbling and vibration problems are gone.
the transfer case flange was really loose, we tightened that up, but I think they got a little too crazy on it, since I hear a whining noise from under the car now. So, when I get a new set of driveshaft bolts and we go to swap out the old set, I'll have them adjust the flange a little so it will quiet that up, and the car will be fine for a while (knock on wood)
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Daim
Nov 28, 2016 09:28 AM
James007
Oct 3, 2015 03:29 PM
Whitnessmouse
Sep 4, 2015 11:09 AM
