Any tricks to removing the right axle?
Old Jul 2, 2008 | 10:14 PM
matl's Avatar
Default Any tricks to removing the right axle?
Hi guys ive been fighting with the right axle with little success. I cant seem to pry the ball joint from the lower control arm, i can get it to seperate about 3/4 inch but then it binds up. I've tried seperating the hub from the strut which is impossible and i've even tried disconnecting the strut tower to drop the whole assembly with no luck... i'm so frustrated. Currently i've got the break rotor off for easier access and both bolts on the control arm loose to lessen tention, tomorrow i will go pick up a fork to see if that gets me better leverage on the ball joint. Any advise would be greatly appreciated, thanks.
Old Jul 4, 2008 | 02:21 PM
matl's Avatar
Default RE: Any tricks to removing the right axle?
Great thanks! Man i'm amazed how complicated Jag has designed these cars...
Old Jul 6, 2008 | 03:07 PM
matl's Avatar
Yes thank you! Axle is out and from what i understand now i'm supposed to remove the catalytic converter and the mount but the two rear bolts on the mount are totally unnacessible! Had i known how tough these cars are to work on i probably woulnt have tackled it, very frustrated [:@]
DpezXK8
Aug 27, 2025 08:55 AM
Bill Swift
Mar 31, 2017 01:33 PM
Daim
Nov 28, 2016 09:28 AM
avern1
Sep 6, 2015 04:22 PM
Joey T
Sep 3, 2015 05:31 PM
